Poor render work.
BTCL
I have a semi-detected property which had a bad cement render job to the side and rear. When planning to add a side extension it was decided that the property would be re-rendered - side and rear inc. the new extension.
My builder advised that as removing the existing render would cause too much damage to the brickwork, so Ceresit render would be rendered over the top and would be done in three stages;
1. any prep work would be completed first and the side and rear of the house would be rendered by a sub-contractor, less the area where the side extension was to be built and the window reveals as the windows were being replaced.
2. once the side extension was built, that would be rendered by the builder.
3. any making good the rest of the house would be completed by the sub-contractor.
Now the job has been finished, I am shocked at how bad it looks! Iv attached some pictures to show the quality of the work completed. The builder tells me that any colour difference will fade in time and blend as one. Other areas can be made good.
Any advice before my meeting with the builder and sub-contractor?
Colour won’t fade in time. This is just to keep you satisfied till you’ve paid. Textured finishes can’t be ‘patched’ as shown in one of your pics. Not sure what advise you’re looking for as I’m sure you know it’s bad
U been #caspered, seeing a lot of it lately. some of the reveals look like they have got the layed on and left look lol. Cracking job Casper
Everything builder said & done is wrong
Only solution to this is to get a real pro In
your welcome
The only true way is mono! Did the bloke try and sell you a lurcher and a new tarmac drive aswell by any chance?
