hello i normally use rendaid on all the bits of rendering i do , gonna try some sas pro rend out and was gonna use there prep . it clean concrete block work so will it stick ok with out the prep ?
it s new but been built a good while ago.i rang em today assured me it would be fine, i cost of the stuff make s me worry in case it fails or something
if it aint green with algae and the water has been diverted off the scaffold then it will be ok. If there's terrible limebloom beneath water outlets and mildew everywhere then you will need to remedy these issues first butt
