Have not priced per sqm so need some help,
whats the going rate Labour only per sqm for the following (Aylesbury) : - working as subcontractor to main -
Twin frame 48mm stud (600mm centres) + insulation + double sound block board each side (2.7m Height)
Single frame 70mm stud (600mm centers) + insulation + single sound block board each side (2.4 Height)
MF drop ceiling with 2 layers fire board
