whatever colour you like.Do u know wot colour it is.
looks good painted white.Same as multi or board mate
Same as multi.?? Two coat. One flat trowel and finish. Do you use water whith it to trowel?Lovely gear mate , apparently bandq are stocking it now £9 a bag too
Just the same mate , I don’t use waterSame as multi.?? Two coat. One flat trowel and finish. Do you use water whith it to trowel?
Most paints aren't going to put an impenetrable barrier on top of the plaster. It's designed to be painted and still work. It's nicer to work with than multi but it's a ball ache to get hold of so I gave up with itNot used it , a quick look seems to suggest its multi with a chemical added that absorbs formaldehyde from air to enhance living space , no mention of being better to put on
Seems a bit pointless if its painted
ThistlePro PureFinish
ThistlePro PureFinish is a plaster using ACTIVair technology to absorb formaldehyde and help improve indoor air quality.www.british-gypsum.com
The paint won't affect the health benefitsNot used it , a quick look seems to suggest its multi with a chemical added that absorbs formaldehyde from air to enhance living space , no mention of being better to put on
Yes agree , just being devils advecote , not sure if it'll work with vinyls and really just making a point that info doesn't suggest it's anything but multi or board , the word pure suggests no nasties so how is it better to spread ,
@Robbo123 , @johniosaif , @lurpak
If it white the consistency when dry is the same.? Not like pinkat the time I used it, multi n board was shite. It was just nice to use. But so is multi and board when it’s right. It’s the inconsistency that gets annoying.Could be exactly the same with pure,dunno
Not looked into it , will ring them up and ask , if it absorbs formaldyhide whatever it must get saturated after some time or its converting it to something harmless endlessly which would surprise me , not into chemistry. Yeah my little dig was it being more consistent over multi and board , personally don't like people picking on any form of hidesat the time I used it, multi n board was shite. It was just nice to use. But so is multi and board when it’s right. It’s the inconsistency that gets annoying.Could be exactly the same with pure,dunno
Ok , not had a lot of time but rang BG , reckon it's good for formaldywhatever
For 50 y even with several coats of emulsion.
I'll do some more investigation tonite ,
First instinct from chemistry is it's good call for modern living , formy used in most products as basically a wetting agent predominately in carpets, sofas, plywood, chipboard etc, also in insulation products, s they evaporate into air , as I said modern living and not opening the window , also outside from combustion and Inc gags
Will look into it some more for you ,
Only anti thought springs to mind is , air would have to be circulated as formaldecrap is heavier than air ( only slightly ) and I'm suggesting their are better ways to sort problem than spreading on ceiling. BG also said it's not the only difference over mf and board , it's a secret lol
How do you mix itJust the same mate , I don’t use water
