That's always the case onsiteI had a problem with new board a couple of weeks ago. I meant to post about it but I forgot to make a note of what make they were.
They were bought from Buildbase in Stornoway, Isle of Harris/Lewis.
Weirdly, it wasn't every board, just odd ones here and there - I put the gear on the wall and some would be all right and other areas went off as soon as it was on - very clearly on different boards.
I've never had that with new board before and never heard of it either. Neither had anyone I asked.
I got fed up after the second time it happened and PVA'd every internal wall before I carried on.
Anyone else ever had this?
I would , if it's let's say more than 30m2, but duraline always. Sucks the s**t out of it . We hugely underestimate the air flow the boards are exposed to .Really?
I'm a jobber who can plaster - don't usually do anything bigger than an extension or a bit of renovating and never had a problem with new board.
I used to work for a housebuilder and we'd board in front of the plasterers. We never PVA'd them and I don't think I ever saw the plasterers do it either.
I guess if it happens a lot, then the answer is yes, PVA new board.
Trust me if my walls were made of cornflakes I'd be slapping pva or pre grit on them
Got caught out once on old boards never again.
Clemo killed this thread as well...![]()
Never PVA new boardwork.
I'm very surprised thats even been asked.
Obviously if the boards have been up a year and gone yellow then yes.
But NEW????
I wouldn't but if they gave me hassle I would so I'm 50/50Right - so who's right here?
Either new boards can give you problems or they can't. Should be a unanimous answer from all experienced plasterers.
I've definitely had new boards give me hassle, but I thought it was a one off.
No other plasterer I know has ever PVAd new boards.Right - so who's right here?
Like you say if youve been caught out it must have been either a one off or there was something else going on.
Maybe the boards had been rained on in the yard at some point. Maybe the plaster was one of the crap batches. Maybe they were covered in dust. Maybe they had been walked on by t**t labourers when they were stacked flat but incorrectly on the floor with the good side up.
They ain't made to be PVA'd
Standard rep practice. You must have tied your boots up the wrong method that morning, the plasterboards are never the same if your laces are tied up wrongHad it many moons ago in newton abbott the Bg rep came out and blamed everything apart from the board
Lol I was in a 3-1 gang on a hospital and every plasterer was getting the same flash sets when boards were coming direct from factory 3 in they was still warm don't know for 100% if that played a part in it but plasterers with 30-40 years experience being told it's not the board or plaster but a dirty whisk water is different in this areas hawk dirty trowel got a bit of build up on it to not a spotless bucket didn't exactly go down well even got told to 2 coat with same gear bit hard on a long run but apparently we should just keep dropping back to second coat like that would happen anyway he took a sample and we never heard from him again funny enoughStandard rep practice. You must have tied your boots up the wrong method that morning, the plasterboards are never the same if your laces are tied up wrong
