PVA OVER DAMP BONDING?
Jimbo95
Had bad experiences skimming over fresh bonding. Once bonded a chase waited a few hours till it was hard enough and gave it one (pretty watery) coat of pva and it done the trick, never sucked in.
Is this a suitable method or could this hold back moisture and cause problems later? I never had any complaints from it.
It’ll be ok
Yes shouldn't have problems skimming same day over bonding (should be low suction) but it you want you can use a 4-1 over it before skimming.
no
Ideal time to go over undercoats is same day.
Brilliant Thanks a lot appreciate it. I would rather pva it rather than just goi g over it.
