Radius wall
Djr
Can anyone recommend which beads to use on a radius wall that's getting done in Weber pral m 15mm?
I have used the arch beads before rendering and just double beaded one on top of another
Bit long winded but before we've used standard 15mm angle beads and made a cut every inch along one side.
That enables you to bend it.
Yes I've done that myself but the rulers always kink or look like a 50 pence piece.thought there might be a bead out there to form curves like the plastic arch beads but for render ?
The normal skim ones but put 2 or 3 on top of each other to get the depth
I am trying to achieve 15mm thickness pal .I don't think skim stops would be suitable for render imo
The rulers ha ha ha. Fukers I meant
