John j
Mono Don
You best get to post office then for ye trowel fundsThink I'll treat myself to one 14 " though
Or if you buy one you.ll have a box to post mine inThink I'll treat myself to one 14 " though
Ok lolOr if you buy one you.ll have a box to post mine in
Yes but can't see any rivets but no additional strip like on there flexis so confused how the f**k it stays together!
That's good welding when you can't see the weldWelded
It's hard to see the rivets on refina trowel compared to other trowels but they're definitely thereThat's good welding when you can't see the weld
It's hard to see the rivets on refina trowel compared to other trowels but they're definitely thereView attachment 41912
Yes mate, there's rivets through the handle on to the narrow piece of steel and that's glued to the main trowel bladeThought they were glued on
Are refina trowels made by nela or vice versaThe grinding at the bottom hides this, its all done by machine so will be very neat and tidy
Ain't nela made in germanyRefina are made Maurerfreund in Germany
NELA are made by NELA
Jodie from rafina says you're wrongThe grinding at the bottom hides this, its all done by machine so will be very neat and tidy
Is rafina the jamaican branch haJodie from rafina says you're wrongView attachment 41920
Yes mate I've got nela trowels refina and marshalltown refina rivets just aren't as visible but they are there if you look carefully
Riveted same as refina but more visibleIs the NELA riveted or Welded?
So these are bolts not rivetsHere are the differences View attachment 41924View attachment 41925
The bottom being the NELA Premiums patented design. The above is the generic version used by many for a bracket which has welded bolts pressed
So these are bolts not rivetsView attachment 41926
You learn something everyday
Hope you didn't cut that trowel up just for me amazing the work that goes into them,
Are the marshalltown must still be riveted are they
They look as good as any the good thing about ox is the convenience you can just go and pick them up from any local builders merchants, Johnstone's decorator centres are going to be stocking refina tools after January,Used the ox ultraflex today. Like it. Few hard crosses to stop it digging in n good to go. Better than the mt flex n half the price
Yes mate that's true,flexy trowels a flexy trowel.
I use refina s*p*r*lex trowels for laying on skim coat over mesh on thin coat jobs they've got a wide blade 125 ml holds the gear when laying onView attachment 41936
Fuckinghell it does micro machinethat car infront looks like it’s been squashed
Told you bud you can use them for wetting up and polishing leaves leaves lovely finishUsed the ox ultraflex today. Like it. Few hard crosses to stop it digging in n good to go. Better than the mt flex n half the price
