Refina MM30 mixer
yeah ive got one theyve got two speeds 230rpm and 560rpm beast of a paddle it will spin a bucket of drywall round with three bags in bulletproof heavy like compared with the mm21 but best allrounder if your doing internal and external
i know its not always meant for mixing render but we did a 12 shovel of sand in bath of render and it took about 15-20 + mins to mix up!
oh john i just sent u a pm
Speaking of these H frame mixers ive just replaced tbr cable on mine but im having trouble with the trigger now its a tw@ to get to sit right properly now its sticking any one know how to put them in properly
just dont look slow to me on vid - it should churn the gear over with little effort tho. most products are better mixed slow too
got ur pm
just had exactly the same problem and ordered a new trigger for 26 quid ill let you know if the new one sticks
Should've just used the shovel to mix it it would've been quicker ;)
mate i have been there .... they are real tricky to wire up properly
we had the same problem on ours a couple of years ago. it ended up the wires werent sitting right when we put the handle back together
I have the same drill ,sounds and looks like its working fine mate , maybe youve just got use to a faster drill .
no difference in power etc mate i had a d handle drill for years its just what youre used to their still sh1t hot drills ;)
Skimming doesnt like to mbe mixed to fast. To get the drill to mix properly you need to completely cover the wisk in gear else it just flings it about and makes a mess
Just go to wickes and a get a plunger, £7, and wo`nt let you diown.You have a labourer, let him earn his dosh instead of buying him expensive tools.
Or a £9.99 drill from b&q & a £3 paddle.
It won't let you down either........ ;)
i had teh 1800w thing so it was a heavy drill any how.
