DominoRemoved
Link Removed
now thats tiny
pump up to 10 ltr/min
110 volt
now thats tiny
110 volt
will run off a single phase supplyThe pump is fitted with a 2" diameter statorThe screw pump uses the mono pump principle, withrotor and rubber stator to pump and spray heavybodied coatings, finish plasters and waterproofingrender, fireproofing and textured paints, grout andcement coatingsThe EEG17 lance spray gun uses 15cfm at 45psi andis supplied with an 8mm nozzle as standard; 4mm,
6mm, 10mm and flat nozzles are also available
