Render and skim
I have done plenty of external rendering, but haven’t done any internal for 20yrs since I was an apprentice, Just built a new build and sick of D&D.
What mix should I use? It’s onto standard breeze block
I was thinking 5:1 with plasticiser, one coat about 12mm
Thank you
Lloyd
Thank you
Lloyd
When you say "standard breeze block" do you mean aircrete blocks like Durox, Thermalite etc? If so 5:1 is way too strong, even 6:1 is with every sand I've ever used. 7:1 or 8:1 worked well with the sand I used to use for float and set. One of our local sands really wanted to be used at 10:1.
There a dense 4.2n aglite block, not thermalite.
Thank you
