Hi, looking for some advice.
New build house three years old. It was rendered in Parex DPR Sand Fine acrylic/silicone render, finish Snowball white.
Three years on and it looks pants. Got the Parex maintenance guide and tried cleaning over the past few months power washing with soapy water, Trisodium Phosphate and 251 Lankomousse. All with limited success.
Response from Parex - You have a relatively flat flashing / coping with very little drip (overhang). Airborne particles such as algae, moss, lichen etc will be collecting on that flat surface then when it rains they are washed off and as the water drips onto the façade and if not cleaned with a fungicidal wash and cause staining to the façade.
Their suggestion now is to coat the surface with Parex 310 Primer and/or 311 DPR Coating and Paraguard surface sealer.
I'm disappointed with what's happened with the Parex render in just 3 years so was hoping for some advice from the experts here.
1) Any other cleaning products / techniques that may work?
2) If re-coating, should I stick with the Parex products due to colour match as it will be the easiest / cheapest way to rectify?
3) Any thoughts on whether it's best to use the 310 Primer or the 311 DPR coating? The Parex documents say '311 Coating will alter the texture and sheen of the original finish' but if it makes it more resistance to the build up of algae that may be a good thing.
4) I suspect when initially rendered there wasn't a surface sealer like Paraguard applied. I've seen some comments re Paraguard verses Enewall micro sealers on the forum. Should I stick with Paraguard or does Enewall or others perform better for preventing algae build up?
Thanks for any advice.
I'm based in Surrey. If you can recommend anyone local that could help please do!
Thanks,
GRoW
Thanks,
GRoW
