rendering advice please
lollol81
Hi I have a friend who has had some rendering done on his house over existing and some blown areas removed where needed. Can someone please advise on quality, I think it's pretty poor.
Thanks in advance
not sure what it is but yes finished can see scratch coat under the rough finish top coat.
some more pics. Thanks for the reply
Hi and welcome, post some pics once its finished..top coated scaffold down etc..
Usual questions will be.. How much was paid? How did your friend come about the firm that done it?
What material used?
And was there tea and biscuits aplenty(y)
What material used?
Hi thanks for reply. The problem is this is supposedly finished
Give us the full story... Start,middle and end please(y)
Basically he got quote to remove blown render where necessary then use a rough finish texture all over. basically he is finished bar a little bit round porch apparently. So to me this is not finished anything from pics you could advise.
Thanks again
@lollol81 I would guess that the 'plasterer' has quoted/intended to give a sort of cheap Tyrolean finish, but unfortunately doesn't have a clue as to how this is supposed to be achieved. He will know full well that the finish is unacceptable, definitely. Undefendable.
Hi thanks for the opinion. Feel for the people who have had done.
Just wanted to make sure I wasn't being ott with the workmanship but looks like nothing to defend the guy with.
He certainly didn’t have a clue when it comes to tyrolean which is what he was trying to achieve, I get the make your own kick as we do the same but it he seems to think it’s done in the same way as rough cast. There should have been a flat base coat for the tyrolean not a scratch coat. He could try telling them to come back as it can be done off a ladder if the scaffold has gone but to be honest I think they won’t. It could be covered with a few more coats of Tyrolean so all is not completely lost just find an older spread who was around in the seventies and eighties he should know what to do
