Well that’s the mix I’m doing so fair enough.You need to do a transfer first geez. I’m not for free!
Good luck!Well that’s the mix I’m doing so fair enough.
Thank youGood luck!
Too strong.going to do a 4 - 1 sand and cement with waterproofer for the scratch. top coat with be 5-1-1 sand cement and lime. Don’t know Iime is old school now but I like how you still have movement in the mix once dry.
Too strong.
Just found that ratio on another forum so I’ll go with that to be honest. Does sound pretty weak but I’ll go with it. For the area size it’s worth risking it.@Cockney1 have we received payment yet?
Where you based?
Sheffield.
Pm me if you want some help...just put a silicone render thincoat system over it be alot better!
I do appreciate the offer but I’ve built the whole thing myself, no help on any part of it, even lifting the catnic into place! so I want to finish it all myself.
I don’t want to do bagels render just in case it fails. Budgets budgets.
What does ocr mean? ThanksI would just rendaid that then ocr with mesh that is equivalent to a 6-1-1mix mate or what zomb said
HI thanks for reply. I’ve only done sand and cement and (Weber one coat) before so I’m not confident in trying a costly product. Sorry I should have probably mentioned this.
Its a bagged render mateSorry I didn’t pick up on the “ocr”
yes I can get the one coat render but I can only get it in one colour cheaply and I don’t want that colour. So I’m going sand and cement.
I’m just gonna try the 5-1 6-1-1 sand cement line. We will see what happens
This was done over celcons View attachment 51615
I know i was pissed when i did it hahaRight hand beads on piss!
You can get ocr next day deliverySorry I didn’t pick up on the “ocr”
Thought you said you have used it beforeHmm ok Weber one coat base render. Does it paint up ok? Will there still be suction issues and require rendaid
DealSkim a couple of rooms for me and i will come and put you a nice colour silicone render on it.
Offer lasts until midnight!!!
For god sake. Not used it on celcon blocks.....hence why I made this post in the first place you thick c**t.Thought you said you have used it before
Oh dearFor god sake. Not used it on celcon blocks.....hence why I made this post in the first place you thick c**t.
I’ve never painted it...sorry I’ve never painted one coat render before. Sorry I don’t know everything about everything.
Now let me tongue your mums arsehole.
So what ratio mix are you going for?c**t t**t b*****d cock pussy arsehole w**k*r
What's your favourite brand of beansc**t t**t b*****d cock pussy arsehole w**k*r
