Hi do plasterers render up to new external finish beads or do they cover it up or remove it.
A azzza82 Member Jun 3, 2022 #1 Hi do plasterers render up to new external finish beads or do they cover it up or remove it. Attachments 20220603_165918.jpg 819 KB · Views: 185 20220603_170125.jpg 960.1 KB · Views: 193 20220603_165949.jpg 1 MB · Views: 183
T Trowel em up baby Member Jun 3, 2022 #3 I’d personally take them off they look crap rebead into the frame
R raytheplasterer Well-Known Member Jun 3, 2022 #4 they will put a plastic stop bead against it and then silicone mastic afterwards. 10 or 15 mm whichever size they use.
E Elite exteriors Well-Known Member Jun 3, 2022 #6 azzza1982 said: Hi do plasterers render up to new external finish beads or do they cover it up or remove it. Click to expand... Either or depends who does it
Monkey Boy Well-Known Member Jun 4, 2022 #7 Should do and what is behind them should be sorted to suit
R raytheplasterer Well-Known Member Jun 4, 2022 #8 Monkey Boy said: Should do and what is behind them should be sorted to suit Click to expand... a big gap in the brickwork more than likely.
