eels_up_inside_ya
hi all,i have a rendering question for you guys out there.i recently had to render a inside doorway built out of dense concrete blocks,it was about 25mm thick so i built it up with 3 coats of render cos of the thickness,giving the coats a good scratching.i made the first on 3 to 1 the second 3 and a half and the final 4 to 1 ,using good quality plastering sand.did i use the right mix ,materials etc?it seemed a real solid job when it had hardened.do you think this will stand the test of time or just fall off or something? im looking forward to hereing from you guys over the weeks.see you later spreads.
