ChrispyUK
Just read back, if it takes one cost happy days, if it takes two coats, then thats what it needed..
I’m just pissed and took the bait mate
I assumed you were a home owner and doing it in your own house. You shouldn't have to ask these questions if you're charging someone tbhGreat thanks all, going to repair and use easifill 20. Use a small indirect heater, 2 coats and sand down with 120gt.
finally please, joint tape, needed? If so is Fibafuse joint tape the best option? And if so just over the joints on ceiling or where the walls meet also?
Good decision listening to me regarding sandingUpdate:
Did the job Mon/Tues, using easifill 20, I taped all the joints with fibafuse, both really good products.
I did two coats of the easifill 20 and got a small heater fan on in the small utility room, closing all the doors. I waited 40 mins but the easifill was still wet in parts so decided to leave it and went back the next day to sand down. Good finish in my option, customer happy.
I’ve done an intensive plastering course at Yorkshire Training Academy, very good but doesn’t teach you everything, hence my original post.
Thanks for all the helpful advice.
A little heater nearby then sand down half hour later. Quality stuff again from tpflittle heater works well Pauly. Not directly applied, but nearby. Wouldn’t use a heat gun though.
'Quality stuff again from tpf'A little heater nearby then sand down half hour later. Quality stuff again from tpf![]()
Right again though aren't I'Quality stuff again from tpf'
says the forums resident professional chancer
#Obsessed
Only in your own warped lefty mind you areRight again though aren't I![]()
So you'd sand a filler after 30mins?Only in your own warped lefty mind you are
yes.....about half an hour after 30 mins clever cnnuutSo you'd sand a filler after 30mins?
Righhhht
Oh it's a rental property so you don't care about the standard that makes sense. What you've just described isn't possible in an hour to a decent standardYou really are a tit. Obviously the heater has to be nearby.
I often have to do quick repairs on the rental properties I look after. Someone had kicked in some Pb on stud wall other week and broken the bathroom door lock and frame. Job on the way home. Quick patch on Pb with a bit of 2x1...filler and heater on. Cut out damaged bit of door frame and glued and spliced some wood in. Knock top off filler and recoat wall with heater back on. Finish frame repair and door lock. Quick sand down of wall and sorted. Just over an hour.
Ok, shouldn’t have taken the bait, but I like my little heater.
Ok....yes.....about half an hour after 30 mins clever cnnuut![]()
Still not possible to a decent standard. You can't sand Easifill for several hours at leastjust over an hour...keep up.
In an ideal world, everyone would just let everything ‘air dry’. Good job you get talcum powder in your Xmas stocking!
I I captainGet a little heater.
A hairdryer works well once it has set. So I'm told. Not that I ever would of course.little heater works well Pauly. Not directly applied, but nearby. Wouldn’t use a heat gun though.
"already drying" it's all already drying, it's drying from the moment you mix it. What you need is it to be already dry.Fibafuse, then 3 coats of easifil 20, feathered out, the edges are already drying (the only bit that needs a rub if you know what your are doing), job done in an hour. At 6.48 I had sausage rolls, beans and chips.
Don’t need to sand it if your the f**k**g masterAbsolute nonsense. Easifill 20 can't be sanded down after 20 minutes and certainly not when it's been done in 3 coats
Just correcting incorrect statements. Full time job on hereSeems a awful long thread for filling a few screw holes that popped! Did the proffesor complicate things again with his awkward nature.
Why I like that so much
Well thats not you is it?Don’t need to sand it if your the f**k**g master
