Replacing S&C render with lime?
philj1
Hi,
First time poster who knows nowt about plastering.
I bought a 1890s terraced house in 2010. The walls are solid and the back wall of the house has a damp problem. It has a sand and cement rough cast render that has been patched by the previous owners. The inside is also plastered in sand and cement. There are three damp patches down stares that are slowly growing. There is no mould on them but there is a furry deposit that falls of like dandruff. When I put a cable through the wall the brick dust from deep inside the wall was damp.
A few days ago i chopped some of the render off the outside of the wall and it was damp behind the render, which sounded hollow and came off very easily.
I have checked the gutters and they are all fine. The roughcast wasn't painted up until last year when I painted it to see if it made any differece. It didn't.
My questions are
- Is the cracked cement render the problem?
- Do I need to have it replaced with lime render and if so, do I need to do the whole side of the house or just the first floor?
- Do I need to do inside as well?
- I would never attempt to do the plastering myself but would I save much money by doing the hacking off myself?
- when hacking off does everything have to come off? The top 15mm practically fell off where as the 5mm against the bricks is stuck like sht to a blanket.
Sorry for so many questions but I would greatly appreciate any advise.
  • Replacing S&C render with lime?
Hi, yes the best thing to replace the render with would be lime. It will help the walls to breath and once dried out all your damp problems should disappear as you have said there are no other signs of it, ie leaking gutters. You are better off with replacing it all with Lime to be honest. In a perfect world inside and out would be best but with all the upheaval and fuss it could cause, easier to start outside and go from there. Best bet would be to get all the render off, as much as you possibly can, not every last bit as in the last 5mm but as much of that as you can. Then leave it for a few weeks if you can just to give it a chance to dry out a bit before getting the Lime on there. Where abouts are you in the country?
Thanks Bodders.
I'm in Bristol. Know any decent lime specialist round here?
And what am I looking at? £40 a M2?
