Hi, I'm building a small rear porch between the garage and the back door. I'm using a timber frame with concrete tiles over.
The external finish needs to match the existing which is a S/C render so need to use a rib lath system to support render.
The wall which needs facing is only 3M x 2.1M and will be fairly sheltered even though it will be facing west.
Do I need to use stainless riblath or will galvanised do?
Richard
Richard
