Minh
Not religious at all,I just like a good laugh.:RpS_thumbup:.... keep up the good work:RpS_lol:
OMG, A compliment from Mr FatArm! (Mine's muscle btw) :RpS_thumbsup:
Must be the badminton you play? Or w***ing:-0
Badminton requires the body to be relaxed. I have hardly any body fat so my muscles look ripped. I'm starting a new company this year: the Buff Plasterer. I'll charge desperate cougars double to see me in my thong :RpS_biggrin:
NOW,who will have quotes like this?For guys I charge triple or quadruple for an oiled up body. No touching or my pimp will beat the s%#* out of you :RpS_biggrin:
Ankers,
This is the how I teach my students the difference between ripples and tiger stripes.
Question: What causes ripples?
Answer: Plaster that has been laid on too thick.
Reason: When you pass the trowel over a thick coat that has not pulled in yet, you end up causing some parts of the plaster to slide over itself causing ripples. Multi finish does not like to go on thick because it cannot hold its shape properly. When you approach 6mm you will notice that multi begins to sag under its own weight.
Solution: Let the plaster pull in more, and apply light pressure when laying it down. You also need to frequently discard of the excess plaster that has accumulated on the face of your trowel.
How to improve: Don't lay on thick coats, 2mm followed by 1mm is the way to proceed.
Question: What are tigers stripes?
Answer: Lines caused by a trowel that has been opened up too much when wet troweling.
Reason: When the trowel is opened up, you begin the process of scraping instead of spreading. If the trowel is opened up too much, instead of just scraping away minor lines you also end up scraping away hundredths of a mm from the surface. Even on a relatively flat surface, those hundredths of a mm will end up leaving cosmetic tiger stripes when the plaster dries (in most cases these stripes are not noticeable when the surface is painted).
Solution: Don't open the trowel too much when wet troweling and make sure the face is always wet. Only move about 12 inches at a time otherwise the water on the face of the trowel will run out and you then run the risk of tearing the plaster.
How to improve: Keep the trowel wet and work in small controlled fan shaped sweeps. Don't apply too much pressure and always overlap the previous sweep. A fast and smooth sweep is what you should be aiming for.
Im getting tiger stripes when skimming on board lately and ive never had problems with it before not changed anything ive been doing such a pain in the ass did a big ceiling today and it striped like mad i did get them out in the hard trowel. you cudnt feel them on the surface but could see them. they are so frustrating. how hard do u lot let your 1st coat go before u top it?
Its all to do with thickness of the coats what causes them
cagoule or donkey jacket ? which one would cause them :flapper:
A snorkel for first coat,.. a parka for second coat.:RpS_wink:
This is a bit like the how long is a peace of string question.To me the answer is simple ,you have to work with the plaster, not all sets are the same ,some take early ,some take ages to go. Its all about experiance and good skill with the trowel. I have found that the multi finish has changed so much in the last 12 months it now requires no water or a very little to trowel up , i have even gone back to using an old carbon steel trowel that i have had for bloody years to trowel up with as i find it gives a better finish. Don't put on more than you can handle, keep each coat as neat as poss ,dont lay in when the first coat is to wet ,and don't put on to thick. when you start the first trowel you will know straight away what is required so adjust your method from there.
used multi a long time ago and changed to board, a new builder got me in but already had multi on the job so i had to use..............best thing ever. multi is so much better now than it was a few year ago
Your joking right?
