Had plaster all the way through mike from where the air on/off knob is to where clear air plastic hose on the right,I've just sprayed belle cleaner in it to hopefully un block,if I blow through it or pour water it don't come out,here is plastic struggling to clear this as wellive not got that valve on mine are you sure it's open if its hitting in the same place there shouldn't be plaster there
Definitely is spent 3hours getting it out with the cleaning rodsI was saying that to u pete how did skim get in the air line. Are you sure there is skim in there.
Okay good shout I try that,thanks mikeundo the nut under the knob and should come out same as a tap
Yes at first I didn't want to drill to hard then I realised it was totally full of plaster..drilled a little hole then used rods and belle cleaner to wash out crapDid you try a small drill bit yet
Any idea why plaster got in there mike ?ive not got that valve on mine are you sure it's open if its hitting in the same place there shouldn't be plaster there
Cool I get one thanks for the heads up.Vince machine mart do a kit that's good for cleaning pipes. Don't know if you've already got one
https://www.machinemart.co.uk/p/clarke-sck19-19pc-spray-gun-cleaning-kit/
Lol no .. Can't find my spanner's ffs.. Buy a new set tomorrow and take that nut off what mike said .. Think can clean it out in that bit when nut is off . Tbh think I have to get a new bit of pipe just can't get it out of there,no spraying for me on Tuesday,ffsSo have u got it sorted yet
Goods news me 2 new tap connection came today..put it in my tool bag and found one in there already lolSo have u got it sorted yet
I thought that would work but it's hard set plaster any bits I get out with rod are like putty hard but like soft play DowPete can you not just tap it with a rubber mallet or a wooden mallet.
I give it a go last chance saloon here,loltry leaving it in soak overnight in water
In the air valve part do you mean ?Is there any rubber inside?
YesIn the air valve part do you mean ?
Find out tomorrow mate I got to get spanners from shop to open it up and have a look inside.
Thanks , it's in bath tonight in water like Ritmo man mike said hopefully be okay.Soak it in a pan with a few bags of extra time, knew it would come in handy oh and it's not a joke
Think I got all I need now to sort it !So have u got it sorted yet
Is that a superprof or whatsitscalled trowel?
Oh yeah didn't see.. that's my new trial Beroxpert inside corner twitcher..ohh yeah !! Came with some parts I ordered..pretty coolIs that a superprof or whatsitscalled trowel?
Don't mess about spraying skimming, ask the PFT bots about the spray lance and get yourself a marshalltown corner trowel, cut the sharp edges off fine sand with wetn dry then break in for skimming.Spent afternoon getting skim spray gun cleared out , found set plaster in air pipe in gun,took most of plaster out but just can't get last little bit unblocked near the air adjustment knob,any tips ?
View attachment 13429 View attachment 13430 View attachment 13431 View attachment 13432 View attachment 13433
