Eerrrrrrr???No one drinks in the South
We tried the smaller nozzle first. 8mm is it? It needed two passes really. But the finish i was impressed with. We had to move up a size though as had done side by hand and wanted the back to match. Looking at it there wasny much in it between the hand and spray. Im clearing the site weds. Ill take couple close up pics to show u.How did it come out dan?i have a big one coming up and want to spray the top coat but not sure on the heavier finish than by hand.the guy has said he wants a flat finish
I did give that a go at first but gave up as although if you stay close to areas just sprayed found myself not really needing to touch it much. More just a quick float on reveals to tidy internals up reallyCant you spray the top coat and rub it up like in that vid of those Germans I recently posted?
We gave it two just because it didnt look right looked too bare if you get me. 2nd pass isnt as full on as the 1st.Why did you have to spray in 2 passes mate?
Im not quite convinced on a 1mm maye on a big area. The grains gotta be so close think it would be hard to make look right on large areasI personally think 2 passes is better I also think a smaller grain than 1.5 would look better.
My thinking is...If the grain is smaller the flatter the finish.Im not quite convinced on a 1mm maye on a big area. The grains gotta be so close think it would be hard to make look right on large areas
Has he ordered that machine yet? I want that 10mm spray cap you promised me.1mm grain is shite
Why's it shite? Other than the basecoat has to be perfect1mm grain is shite
Not really . You end up with more space between the grains
It's really hard to get it right. Twice more effort and the slightest mistake will lead to disaster. Also it covers less m2 compared to 1,5. On the other hand if you get it right is the best finish.
Agreed, the slightest mistake will show up. You need to be spot on with the base coat.
You should get more m2 out of a smaller grain size though
Write away mate. Its on your account!I best start writing him a shopping list then.
@Wezly said youll give away the new gun and a lid as a freebie when i orderNo not yet mate he needs to get a wiggle on though cos that spraycaps starting to wear out a bit
Never happened and never will. It took me quite long to stop trusting the labelsAgreed, the slightest mistake will show up. You need to be spot on with the base coat.
He can afford it. Ive seen his house!That's ok Dan ... Il just put them on his account as well lol
That house is the reason I ain't got any money.He can afford it. Ive seen his house!
https://s24.photobucket.com/user/da.../2015-05/20150527_114806_zps5dlqmoqx.jpg.htmlHow did it come out dan?i have a big one coming up and want to spray the top coat but not sure on the heavier finish than by hand.the guy has said he wants a flat finish
https://s24.photobucket.com/user/da.../2015-05/20150527_114817_zpsdozyf8hz.jpg.htmlCant help but think this is a synthetic version of the old Tyrolean?
I think I would have a job selling it?
Left machine right handBoth machine![]()
