Ritmo, swing gun and parinter.
Wezly
I have to spray a thin coat of parinter with the ritmo, I shall use the swing gun but can i spray it with a 19mm hose instead of the 25mm or will it struggle pushing it through the skinny hose?
Standard RS, I don't know how much the 19mm hose is. I need to get Stuart to get me one. Did you get a right angle bit for your swing gun? Work ok?
I use the 19mm hose on bucket coats and have used it for adhesive coats. Its more narrow (same width as the swing gun)and therefore lighter and easier to use. The swing gun connects directly to it with no adapters.
What you paying? The 25 is to big
no I never did get a 90 degree sorted. Just doing it by hand instead
