Salty Deposits
Johnathon
Hello All
Just quoted on a house that needs 2 walls skimming that were damp due to a leaking drain pipe. pipe has been moved and all fixed, wall just has salty deposits from the drying, its an old Victorian house that has no cavities within the brick walls, is there anything extra I should do than a normal skim in respect to the salt deposits / no cavity and is normal plaster ok for the job. help appreciated, cheers
Johnathon
you can buy salt neutraliser from the builders merchant, just paint it on before you pva and allow to soak in and dry..
you can get stuff for that too...
they call it..beer ;D
