Have you tried the selco version? It’s bloody brilliantUsed bond-it for years but found it didn't kill suction, blue grit even worse.
Grit- going off on a bit of a tangent but it’s bloody brilliant!Pva or grit?
But they do do a gd sbrPva or grit?
Has anyone mixed Sbr with pva and applied to surface then skimmed?
What ratio of each ?Yep
Only when needs must.
It's like an upgraded pva.
Used SBR for first time on interior over skim yesterday. Reason I used it was I didn't like look of painted surface to be covered. Don't think it would have took (some dodgy paints out there) Stuck first coat on while SBR tacky, worked a treat held back nicely. Knocked whole room out. Tried picking a bit out today see how it's bonded, sticks like s**t. I'm impressed. Have to try it a few more times to see how it works in different situations.What ratio of each ?
I’m gonna try a few different ones but have an idea in my head
50/50 Pva and sbr. Seal and skim was talked about on here last year. Real pours surfaces I seal with gardz then Pva. Gardz will neutralise wallpaper paste but seal artex really well. Beeline do a sealer similar to old artex sealer plus loads of primer sealers on the market you can bang on. Let it dry then Pva and skim. It's whatever works for you I guessHas anyone mixed Sbr with pva and applied to surface then skimmed?
Have you mixed them together and applied as one ?50/50 Pva and sbr. Seal and skim was talked about on here last year. Real pours surfaces I seal with gardz then Pva. Gardz will neutralise wallpaper paste but seal artex really well. Beeline do a sealer similar to old artex sealer plus loads of primer sealers on the market you can bang on. Let it dry then Pva and skim. It's whatever works for you I guess
Cracked open a pva this morning that had been in garage for about a year. Gone gluppy I reckon frost has got to it. Don't know if I should take chance on it or just throw it.I have a huge lounge ceiling to do in feb so may just SBR it as I have a tub of it kicking about in the garage
That's what I read.. Mix together 50/50. Don't remember if you need to add water to thin a little but I guess so. I've never tried myself.Have you mixed them together and applied as one ?
Gonna try 4 parts waterThat's what I read.. Mix together 50/50. Don't remember if you need to add water to thin a little but I guess so. I've never tried myself.
