Buy a screwdriver you daft c**tThere’s nothing in this trade athat annoys me more than a plumber leaving screws in the wall for his radiator brackets. An absolute pain in the arse to work around. Takes a chunk out of the trowel and slows the whole process down.
Get some plasterspot indicators.There’s nothing in this trade athat annoys me more than a plumber leaving screws in the wall for his radiator brackets. An absolute pain in the arse to work around. Takes a chunk out of the trowel and slows the whole process down.
I usually just take them outGet some plasterspot indicators.
CruelI usually just take them out
How the tape going tapitCruel
Good to hear it!!Not too bad.
Your good at photoshopNot too bad.
It's real mate. Link RemovedYour good at photoshop
Bout time old Trafford seen a trophyNot too bad.
Was at the cricket groundBout time old Trafford seen a trophy
Did you use it on the wickets?Was at the cricket ground
I take them out. I also fill sockets if the sparks annoy meThere’s nothing in this trade athat annoys me more than a plumber leaving screws in the wall for his radiator brackets. An absolute pain in the arse to work around. Takes a chunk out of the trowel and slows the whole process down.
That's not a solution.I take them out. I also fill sockets if the sparks annoy me
I would but McDonald’s only do paper straws nowStick a plastic straw in the hole, cut it off 10mm proud, skim straight over and when you’ve done pull out the straw
Screw them in tight, mark a line on the floor/skirting with pencil . Skim away and get yourself a set of small vanadium magnets off Amazon for £5. They stick to the screw head and just take them out before wall goesThere’s nothing in this trade athat annoys me more than a plumber leaving screws in the wall for his radiator brackets. An absolute pain in the arse to work around. Takes a chunk out of the trowel and slows the whole process down.
Same I got that tip off here a few years ago...can't remember who mentioned itScrew them in tight, mark a line on the floor/skirting with pencil . Skim away and get yourself a set of small vanadium magnets off Amazon for £5. They stick to the screw head and just take them out before wall goes
Completely off. Started doing it last year wouldn’t do anything else now
It wasnt casper!Same I got that tip off here a few years ago...can't remember who mentioned it
I do the same but take screws out and put clouts in flush that way magnet pulls clouts straight out keeping screws clean.Screw them in tight, mark a line on the floor/skirting with pencil . Skim away and get yourself a set of small vanadium magnets off Amazon for £5. They stick to the screw head and just take them out before wall goes
