S a plastering
Hi peeps got a little garden wall to top off in silicone thw wall has a flat top would it be best doing all the top first or bring it all over as one never really had to do one with a flat section thanks
I have done mateBest to warn the customer of the consequences of rendering on the flat.
Dont want too seperate it mate its going to cover the beads just didnt want to put all the face on first then finding out i had to put the top on first but if it doesn't matter i will just put the lot onThere is a way to separate it, but It’s fiddly job joining the corners and they have to be spot on.
In this case you do the top first, if you are quick enough and try to keep the wet line alive, otherwise top followed by the faceDont want too seperate it mate its going to cover the beads just didnt want to put all the face on first then finding out i had to put the top on first but if it doesn't matter i will just put the lot on
Cheers palIn this case you do the top first.
Edited the post as I don’t know how little the wall isCheers pal
I've got a load of planters to do and the wife was nearly kicking off when I mentioned copings on top. f**k em if it goes green on the top within 12months so be itI have done mate
View attachment 36954this is it
For what mateHope you've typed up your disclaimer mate!!!
For what mate
I know what your saying mate this job is for my sons friend an she knows ghe score its all being tanked behind the wall an like i said i cant give any gaurantees as regards the top ive told em about the copingsI always put disclaimers in for any retaining walls, especially if no copings,cavitys,weep vents etc.
Generaly I just thinkk there a bad idea and destined to fail before the render should imo!
How did you apply the silicone to the top first or just put it all on in one
