Malcolm Tent
Need to skim a couple of walls in a bedroom which has a semi-glossy finish, like a tough resin based emulsion on top of what is probably some fairly old plaster.
The way I see it, I could either run over it with a low grit sander or summut to give a key and then PVA and skim while tacky or coat directly with a bonding agent (I've not used this stuff before) before skimming.
Any thoughts?
Any thoughts?
