no but being backwords formoast can be a c**tDoes that happen if they're upside-down, as well?
A F*****g train driver that hardly works and get paid handsomely...Only reply youve had is from a F*****g train driver!!!!
only a three probably went over your head which is quiet a feat as your probably spend most of your time walking around on stiltsOn a 1 to 10 .
A good 3
On a 1 to 10 .
A good 3
Forgive him, he’s ginger.only a three probably went over your head which is quiet a feat as your probably spend most of your time walking around on stilts
Bloody quiterA F*****g train driver that hardly works and get paid handsomely...
that explains a lot it fits in with the big shoes spotty outfit ginger wig and STILTSForgive him, he’s ginger.
Dont do stiltsonly a three probably went over your head which is quiet a feat as your probably spend most of your time walking around on stilts
heard on radio Thursday no trains from ayr to Glasgow no driversA F*****g train driver that hardly works and get paid handsomely...
You've got to be rich in Scotland to get electricity.To much money some people
just the flower that squirts water and the exploding car thenDont do stilts
5/10.just the flower that squirts water and the exploding car then
5/10.
or lucky to get a plasterer that knows what hes doingYou've got to be rich in Scotland to get electricity.
Dont do stilts
small with boots that sizeFeet to small
Plasticine?hi to everybody,
i was hoping to obtain some information from you guys as i have very little experience with plastering in any of its forms,
i have just had an issue with two walls ,these were boarded out with thermal plasterboard and then plastered however the finished surface is easily damaged, to the extent you can damage it without much effort with your finger nail the finished surface does not seem to be very durable compared with the other walls in the room that are block work with solid plastering, this to the touch in comparison is very hard ,is it normal for the finish on plasterboard to be so soft/easily damaged and what would have been the type of plaster that was used, any information regarding this would be really appreciated .
thanks and regards
When I was a lad I wanted to be a plasterer.A F*****g train driver that hardly works and get paid handsomely...
hi Nicm thanks for the responseSkim sets hard as a rock after three hours approximately.As was said earlier could have been sponged way too late resulting in a layer of flaky fat on the surface.Pictures would help.
it wasnt sponged late and its been painted with a mist coat after it had dried out the damage occured after around a week the surface of the finished skim was polished and has remained smooth like a pane of glass the quality of the work looks good its just the hardness of the finish that is questionable and your the second that has stated skim sets hard so im stumped as to what type of plaster has been used it was pink in colour when it went on the wall so i assumed it was finish coat as opposed to a compound or easy fill as has been implied,
thanks again for your response
the surface itself is firm to the touch provided you dont hit it with force it is plasterboard dot and dabbed to the wall, however as mentioned the slightest press with a fingernail or edge of an object will leave a substantial mark in it however this is not right down to the plasterboard
h ichrispyIt hasn’t been skimmed with multi or board finish then. One of the ‘lockdown’ plasters!
