does anyone use one on thin coat base coats
Looks the business you still have to final polish with trowel ?Use it nearly every day on skim. Even on good Friday [emoji108]![]()
Order them direct mate here's the siteYou have to get them online or order through merchants ?
The ST is blue plastic blade for flattening passes 2 or 3 times when plaster is on and wet, SF is for final finishing (last flick over) , I'd recommend start of with 600 size , see how you goI'm on it cheers lads
Sorry did you check it with @flynnyman that you can post a link? He's hot on it at the minuteOrder them direct mate here's the site
https://speedskim.co.uk/
I don't have to mate I'm running this place nowSorry did you check it with @flynnyman that you can post a link? He's hot on it at the minute![]()
PmslI don't have to mate I'm running this place now
The buy out was successful?I don't have to mate I'm running this place now![]()
You know the score, HardcoreThe buy out was successful?
I'm presume @Davy sned is gonna be using them for the first time on domestic work, tbh if he was doing bigger areas with nothing in the way or site work with just plasterboard to flatten a bigger one might be ideal but don't see the point of advising someone to go for the bigger ones then be totally put off by it because he can't get on with it or use daily,
Standard 12ft x12ft bod standard room a 600 is easy to cover all areas with and won't be clonking the centre light cable on ceiling with it, same on walls he can work from ,away and around plugs and small areas and also flatten all window reveals which isn't possible with 1.2 or above imo anyway
