Speedtrowel
Hello all I started using the 1200 Speedskim today, here's how it went -
The room was a large bedroom with new gyproc ceiling, 4 walls that were were plastered and painted, had wallpaper on them for years, all stripped ready to get plastered,
- taped the ceiling and cracks on walls.
- pva the walls,.
- plastered the ceiling and one wall,
- first coat on ceiling immediately over with Speedskim 1200, took under a minute, - fantastic, flattened any trowel lines,
- immediately put on 2nd coat in ceiling.
- put first coat on wall,
- Speedskim 1200 used to flatten in,
- put on 2nd coat on wall.
- back to the ceiling using the Speedskim with a gentle spray of water over the ceiling under a minute again, ceiling looked fantastic,
- onto the wall - same as above looked great, I was really really impressed,
I went over the ceiling and wall with the Speedskim a total of 4 times after the plaster was on,never used a trowel on it, wanted to see how it turned out, I am really really delighted the Speedskim saves you some work and time, can't rate it highly enough
- next cut my beads for the window wall, mixed the plaster and put on the other 3 walls, and done the exact same as above, result - fantastic my first time using the Speedskim 1200, highly recommend it,
- only time used my trowel was on the window wall and round any sockets, the room looked good, showed the tiler on the job at the end of the day he couldn't believe I never used a trowel on it,
This is the first day of the job, really delighted with the Speedskim, this would be great on any huge ceiling or walls, total time saver, let's you put more on at any time, finished nicely with minimum troweling.
Sorry for length of post as you can tell I'm happy with the Speedskim 1200
- pva the walls,.
