Thought i would give it a go, now i used to: lay it on with ss trowell flatten in if it had gone a bit too much then lay it in, flatten it in with ss trowell, then wet trowell with carbon trowell and final cross trowelling with carbon leaves a lovely finish.
The speedskim come along first and i started to use that to flatten in 1 coat straight away (as soon as I've chucked one wall on ill flatten it in, it takes about 1 minute.) then another wall flat and so on, then turn back and top it. Saves a bit of time yeah defiantly.
Now the other day i spotted one of them plastic trowell with a midget trowell by refina. Bought that and a sponge float.
Used it a few times like this: lay on speedskim flat and then top coat, leave it to pick up and sponge it up, get back on it and flatten with plastic. Now by this time i have visited the walls twice so going the way i usually do one more trowell and it should be all good? Erm no it looked cack. So i gave it a little water and plastic trowelled it then dry cross trowelled it. Very nice and shiny but not very flat, plastic trowelling seems to go with whatever is there. Don't like it, maybe i was doing it wrong? Was using board finish background white board. Only good use for the plastic is if you wanna shine the walls up.
any tips ? Seems like a lot more work for negative outcome.
Cheers Ben.
Cheers Ben.
