U not a fan then? I think there good..cudnt think of owt worse now than doing it all with trowel onlyDepends on what angle your positioning it in. I think the best angle is 90 degrees against a wall with your coat on it.
Bend them instead with your fingersMy first attempt with them was ok I've had a bit of a nightmare with the corners leaving lines tho.I might round them off slightly
Ive rounded mine off but just get the line out with ur trowel straight afterMy first attempt with them was ok I've had a bit of a nightmare with the corners leaving lines tho.I might round them off slightly
If you know how to use a trowel properly then you wouldn't need a speedskim.U not a fan then? I think there good..cudnt think of owt worse now than doing it all with trowel only
And if you want to make hard work of plastering keep using a trowel onlyIf you know how to use a trowel properly then you wouldn't need a speedskim.
If you had bent them back instead you would be able to finish with itIve rounded mine off but just get the line out with ur trowel straight after
I used to think the same mashman. I've had mine a few months now and use it for the first flatten. It's not revolutionary but makes the job a bit easier imo.If you know how to use a trowel properly then you wouldn't need a speedskim.
No its not plasticWould s spatula no do the same thing as a speedskim
Try it on your second as well see what you thinkI used to think the same mashman. I've had mine a few months now and use it for the first flatten. It's not revolutionary but makes the job a bit easier imo.
I do. Just didn't explain myself too clearlyTry it on your second as well see what you think
Ok pal...............If you know how to use a trowel properly then you wouldn't need a speedskim.
Thought that was a upside down picture of the sea there pal..;-)It's not the best of lights for a glory photo shot to show but went over this with Speedskim 4\5 times to complete finish newish 600 blue blade only time pulled out the Mt was to tidy/sort some of the edges/corners
Exact same method as us..i cant get to grips with that eze myself if u go over eze a couple of times then its a nitemare to give it a final trowel with s*p*r*lex I find dont know wat I'm doing wrong just cant seem to like itI don't use the eze spat anymore. It makes it harder work for me. Does something to the surface I don't agree with. Speedskim after 1st, 2nd, first trowel with normal trowel then s*p*r*lex until finished. Perfect every time.
I do that on walls.. All looked lob sidedExact same method as us..i cant get to grips with that eze myself if u go over eze a couple of times then its a nitemare to give it a final trowel with s*p*r*lex I find dont know wat I'm doing wrong just cant seem to like it
U and your selfy stick
