sq meters ??
Depends on the spread, weather , rate, access, panel size, conditions, abutments, scaffold, mood, atmosphere,labourer, inclination, blood alcohol levels, bootlace tightness, sperm drainage levels, substrate, suction.... I'm sure I've missed other factors out
In the past when I used to lay on walls, like that, it was generally expected that the average footage a plasterer would get on in a day if there was a hod carrier on the job and the walls were a nice clear go of it would be around 100 sq. yds. which translates to around 85 sq. meters / day. As Olican was pointing out above you have to then start lowering the meterage by all the extra factors, if inside is it new construction or do you need to protect areas adjacent to the work? Can you mix your material close to the work? Think about all those extras, access to water, washout, power, stairs, insane home owners (as recently mentioned in another thread) ….
Im all about the quality
sq meters ??
I don't want to be the fastest or the best Andy, just the best paid.
Although it is true as a slightly above average spread and being a well oiled machine I can honestly say id piss 15-17m2 a day which is meterage some of the sausages on here could only dream of.:numberone:
sq meters ??
Just kidding wiv ya Scott
sq meters ??
Now that you've changed the dynamic........ How much can a sausage spread?
