How long have you been plastering?Yes or no, customer boarded it up,just needs skimming,any advice welcome
About 30 years.Started mixing browning in a bath in site work,mixing finish in a bucket with a stick and posser.Helped with boarding,got decent at it.Started trowelling up walls for bloke I worked for.Carried in from there,got a nvq from a night course at college.A lad had someone let him down,for this job,so I said I would help him out It's a garage conversion no idea why he boarded it ,in moisture boards.Was hearing mixed messages on whether to use PVA,SBR,grit before skimming,so am asking on here.Thanks is that enough infoHow long have you been plastering?
I guess you've never read the specs on the back of a bag of multi then?Yes or no, customer boarded it up,just needs skimming,any advice welcome
Well you’re a feisty little cherub ain’t you!About 30 years.Started mixing browning in a bath in site work,mixing finish in a bucket with a stick and posser.Helped with boarding,got decent at it.Started trowelling up walls for bloke I worked for.Carried in from there,got a nvq from a night course at college.A lad had someone let him down,for this job,so I said I would help him out It's a garage conversion no idea why he boarded it ,in moisture boards.Was hearing mixed messages on whether to use PVA,SBR,grit before skimming,so am asking on here.Thanks is that enough info
Typical Cockney know it all clever c**tWell you’re a feisty little cherub ain’t you!
30yrs and zero knowledge gained.
Go straight on them you bender, put plenty on or you’ll be standing around with your finger up your arse……………. Wait, maybe you’ll enjoy it more?![]()
That's actually in the specs......very few in the trade nowadays work to that principal though just chance their way through life.You definitely shouldn't be skimming straight on to moisture boards, anyone who does is a chancer. BG Bondit or similar, Microgobetis is my favourite.
Including you and the rest of the domestic dildos . We was gritting moisture boards when you was in short pants. Ha hsThat's actually in the specs......very few in the trade nowadays work to that principal though just chance their way through life.
Could you please remind us all of the retail cost of thistle bond it?Should be pretreated with (BG head) Thistle Bond-it for adhesion. Pretty pointless skimming onto MR board as you are introducing gypsum to a moisture resistant material. I’ve seen a lot of failures, mainly above the shower due to the steam. Another thing to consider is the weight of the tiles which can pull the plaster away from the boards.
Fuk me yes I seen it in b n q £90 . RobberyCould you please remind us all of the retail cost of thistle bond it?
So cost makes it ok to do it incorrectly? I thought better of you than that.Could you please remind us all of the retail cost of thistle bond it?
that shouldn't be an issue for a site slag though should it?Fuk me yes I seen it in b n q £90 . Robbery
It's no problem to me dickhead I do t use the horrible shite thank fuk . Now get to wickes with your tape measure hanging out of your homo snickers pantsthat shouldn't be an issue for a site slag though should it?
If someones moaning about the cost of materials to do the job correctly you are either not pricing up right or you need to work for better clientele and fk the HMO's off in Bradford.
lol, really? Now come on matey!So cost makes it ok to do it incorrectly? I thought better of you than that.
You need to talk to your supplier for thatCould you please remind us all of the retail cost of thistle bond it?
I use itlol, really? Now come on matey!
We all know customer pays materials plus 20%
I’m talking about the tight arse cowboy builders out there, no way are they using thistle bond it @£95 a tub. No matter the colour of the boards they’re all getting skimmed raw dog style.
I use.
A snip at £33.03 a litre.
But it goes a long way Pauly remember.A snip at £33.03 a litre.
It does, and it is.But it goes a long way Pauly remember.
Perfect for those difficult reveals
Blue grit every tight arse builder I’ve done work for use blue grit that’s s**t is horrible stufflol, really? Now come on matey!
It's all s**t and s**t to skim over . That blue dung needs a tight coat of bonding 1st the aggregates that bigBlue grit every tight arse builder I’ve done work for use blue grit that’s s**t is horrible stuff
If you liked the Wickes gear get yourself some Microgobetis.wba was good stuff never had problems with that and was a good alternative to thistle bond it Wickes stopped doing it now
Nice one I’ve been using that bostik green s**t it’s ok prefer wba but I’ll definitely get a tub of that micro stuffIf you liked the Wickes gear get yourself some Microgobetis.
Wickes stuff is Micro mate.Nice one I’ve been using that bostik green s**t it’s ok prefer wba but I’ll definitely get a tub of that micro stuff
Is that bond it pregrit stuff good?
