tapered boards for spray plastering
devneydutch
Has anyone used square edge board for spray plastering as apose to tapered.
removing most of the tape and joining part of the process
I'd have thought it would add to the work needed to lose the tape. That's the whole point of the taper.
If it went on at a millimetre you’d sand through it. Mines roughly 2 mm
Do you use the skim tape instead of the fibre?
The chap I'm with has spent loads of cash on fibre tape dispensers (looks like summit from Ghostbusters) skim tape works better s it's sticky
Scrim on board joints and fibafuse on internals
