D
Deleted member 32554
Guest
Foam addy needs a damp surfaceNo adhesive would stick to a saturated wall, it was pointless really.
Meant to put adhesive tape.Foam addy needs a damp surface
Changed it nowMeant to put adhesive tape.
Yes i think your right ,remember reading somethingThere is a tape
In the rendering game mate
Made to stick to damp/wet surfaces.
It was only the one reveal that I was playing around with that was damp the two videos with the stop beads were dryNo adhesive tape would stick to a saturated wall, it was pointless really.
it had been raining for a week and torrential the day before, if it was dry it would have stuck.It was only the one reveal that I was playing around with that was damp the two videos with the stop beads were dry
I'm not lying mate I did try it on to dry spots I wanted it to work for you with the addition side of things at least,the blue dolphin tape i use sticks better than it,it had been raining for a week and torrential the day before, if it was dry it would have stuck.
no matter as a direct result of it not sticking to wet surfaces my post on another site has took it to another level
I put a screwed up piece in my back pocket later on in the day I wondered what the f*** it was I thought I had chewing gum in my pocket I couldn't get it outCould be the brick looking at it again it has large grains on the surface, that would be tricky with tape.
Sunny weather tape. I like it. Although not to hot as it may not come off the backing. Mild weather tape?it had been raining for a week and torrential the day before, if it was dry it would have stuck.
if it was about cost site skimmers would use gear which is supplied free.Thing is your trying to hit site market which means mass production and you can buy 5000 staples for about £6 hahaha..which can staple how many beads? Hahaha ull be lucky to shift 50 rolls per year hahahaha
It will be.
Staples have NEVER been recommended by any manufacturer.
Recommended fixing is galv or stainless nails or plaster dabs @600mm centres. (british standard)
my tape is also recommended at 600 centres and will become BS approved.
He can't afford toAs a side note why dont you send out free samples to all those on here that would be happy to provide you with some honest feedback, as tom has demonstrated.
In the long run it could save you a fortune mate
£10 a roll? How long is the roll? @tapit?
10 pound a roll, speechless.I've been told a few times, over the years, that width is also important![]()
6 rolls worth? 25kg box bet I’ve not used 2kg in 8month.
Same here, box lasts a couple of years.View attachment 57117
Yeah use it all the time on insulated boards and tin studs. Or if I’ve not stuck boards and the dabs are awol. s**t scrim to that falls off by the time you’ve mixed, give it a blast of that. I literally can’t see me buy any of titheads tape. Unless @algeeman invented it first. I’d buy loads.
How long do you leave before pushing bead on?Yeah use it all the time on insulated boards and tin studs. Or if I’ve not stuck boards and the dabs are awol. s**t scrim to that falls off by the time you’ve mixed, give it a blast of that. I literally can’t see me buy any of titheads tape. Unless @algeeman invented it first. I’d buy loads.![]()
If they’re floor to ceiling ones I measure, spray, cut then stick. Windows and doors, measure and cut the heads then spray first one will be ready to stick if you’ve a few in a room. I scrim down the bead on the dry edge to.How long do you leave before pushing bead on?
That’s the problem, tape to just fix beads at £10 for 25m. It’s just not needed, just waiting on this coroner’s report for this horse. It’s sadly got shot because nobody would back it.Staples, roof nails, various tube adhesives, scrim. and now carpet glue.
BEADFIX is the only fixing made specifically for fitting beads and from the comments it is obvious the problem needed addressing, Carpet spray? i thought i had heard it all, any of you time served old pros use carpet spray or is it just @Topspread16 ?![]()
Manufacturer recommends 3 to 5 mins for solvent to evaporate before sticking. it is not suitable for use below 15c , i guess that rules out a lot of site work.How long do you leave before pushing bead on?
