Cockney
Wally’s blanking me! Lol
Seems a bit steep, think I'll go to Sainsburys instead .For you it’s only a cockle!
In yer dreams son !Wally’s blanking me! Lol
Easy tiger I’m on about tapit!In yer dreams son !
Cheers and goodnight, Gavine has left the buiding .Easy tiger I’m on about tapit!
Fixed that for you!thread open!
Or new celatape. Easier for kids to removecar boot sales gonna be busy as f**k Christmas coming up though so you'll probably shift it all! Glitter it up and say it's tinsel!!!
Why? The bead is proud of the adhesive because it’s sat on top of it, have you never tried a 50/50 mix? A couple of handfuls of bonding doesn’t do much, I’d you tried that over a rough background it just slumps like skim alone would.I can't believe you're skimming over that tbh. I'd at least have scraped off the old tile adhesive. I don't mind a few handfuls of bonding in with multi but I wouldn't be going over that personally
i remember @Tinytom saying he only used 1 strip of tape per bead.
beads should be fixed at top ,bottom and then at 600 centres with a minimum of three strips per bead.
After launch of beadtape i will be attempting to get it approved as a british standard application.
staples or clouts into mortar are NOT BS approved.
I thought it must not be being painted lolWhy? The bead is proud of the adhesive because it’s sat on top of it, have you never tried a 50/50 mix? A couple of handfuls of bonding doesn’t do much, I’d you tried that over a rough background it just slumps like skim alone would.
Another good thing the gear hangs for ages so I had the full room on first coat together window reveals boxing in the lot
It’s being tiled floor to ceiling so it was mainly to flatten for the tiler but you could paint it and it would look sound.
I still scraped all the bigger bits off but that tile adhesive was about 2/3mm thick at worst
Could be the reason especially if it wasn't dry. He had said to tape then pvaYes pal
Read back tapit’s posts mate, he says pva then tape!Could be the reason especially if it wasn't dry. He had said to tape then pva
Stupid tape is peeling of on the top edge! and your ceiling and wall line is fooked!!
No he didn't. But yes his skimming leaves alot to be desired lolRead back tapit’s posts mate, he says pva then tape!
It’s shite tape!! Shite idea!!
I can assure you I’m right on this one but I’m not reading back through all his shite to prove it. LolNo he didn't. But yes his skimming leaves alot to be desired lol
It was actually one of the reasons I slated it because he said you had to tape first and bead second. I said well that's s**t as it's going to take even longer waiting for the PVA to go off before I can skimI can assure you I’m right on this one but I’m not reading back through all his shite to prove it. Lol
Tape first and bead second? Don’t get it.It was actually one of the reasons I slated it because he said you had to tape first and bead second. I said well that's s**t as it's going to take even longer waiting for the PVA to go off before I can skim
Sorry meant PVA second. I just looked back through and he's actually said both at different times lolTape first and bead second? Don’t get it.
either or mate. dry pva or non dusty surface and then pva.Sorry meant PVA second. I just looked back through and he's actually said both at different times lol
No worries mate! He contradicts himself a lot.Sorry meant PVA second. I just looked back through and he's actually said both at different times lol
So your saying it’s only good for plasterboard application now then! Pfft what a joke!The main reason for the fail here is the ridged surface its applied to.
Its adhesive tape at the end of the day and surface needs to be flat.
it would have been good to scrape old tile adhesive of in local areas of tape.
That combined with amount of time between application and use would not help.
It's all very good feedback though and it will be bang on when launched.
