Testing my r&s
wiganlad
Seem to remember stu telling me I could do thus to test the life left in it. And I've a a little pressure gauge that came with when I bought it. How do I actually do it ? Cheers
Got 15 pallets out of my last r/s :RpS_thumbup: best so far, we tend to keep a record on what we have used then sometimes test ,or if it is an easy spray ,put it down the the lap of the gods :RpS_blushing: and have the new one at hand and ready to go
Was testing my r/s the other day.
Are we meant to be building pressure slowly then seeing what the needle drops to and stays at?
If you look at the Ritmo L set up vid on you tube it will show you on there.
As I remember run water through the tester, slowly turn off the tap and when the needle has reached as far as it will go or 20 bar which ever the sooner turn the motor off. Let the needle settle. Ideally it wants to be 10 bar and over.
R&S's in a clamp never gave me consistent readings. I preferred twisters.
