the razzler
can any one recommend the best rendering machines my heads razzeld looking thru them all
Great customer service from @Plasterers1StopShop too matecan any one recommend the best rendering machines my heads razzeld looking thru them all
They kick arse and pump much further than any electric machineI seen a diesel one the other day , throwing it on thicker than I could believe, I’d go for one of them £20,000 ish
We have the mtec 330 from 1 stop,only used it for mono and ocr but been reliable and low running cost.maybe try hiring one for a job n see how u get on.can any one recommend the best rendering machines my heads razzeld looking thru them all
Plus guaranteed back up from @Plasterers1StopShopWe have the mtec 330 from 1 stop,only used it for mono and ocr but been reliable and low running cost.maybe try hiring one for a job n see how u get on.
I only say it like it is mate ..... ere I'm running low on freebies lolCheers Marshy
Think I need to send Ryan some freebies! I might get a better service then lol
Bit on the wet side for me. But for a scratch coat perfect. What mm was that spraying at mate.We had a new diesel machine go out today, check this beauty out
https://mobile.twitter.com/pftcentral/status/926496459645648896
Diesel is king
That went on at 15-20mm in some areas at that consistency, especially when we slowed the machine down. We had already sprayed and scraped the material off that wall so it was wet
Can obviously knock it up a lot stiffer than that
I don't know what you mean.It’s cause you flirt with CCF! I don’t!![]()
That might be true, I only order the odd roll of sticky tape.I've got tried and tested with @Plasterers1StopShop That's the difference
