Chris W said:why not batten the wall out with 25mm tile lath and use a vapour barrier..
insert 25mm cellotex inbetween battens, vapour barrier (screwfix nice and cheap) over the top then use normal 1/2" board with 25mm drywalls...
better fix, better job..
and twice as drawn out, just dab yer thermal boards as mentioned previously done and skimmed for dinner :
sounded like he wanted em to be removeable in the near future.. otherwise... yeh, dab emwarriorupnorth said:Chris W said:why not batten the wall out with 25mm tile lath and use a vapour barrier..
yeh i suppose so... ive just done it before with old boards and an offcut of dpm... same difference really.. foil back better job though..madmonk said:chris would it not be better using duplex boards instead of vapour barrier
How would he remove the boards after if they are skimmed up? or are they not skimmed ? confusing post this , you kneed to elaborate more on your post if you want the right answers, instead of every one guessing at what your after Mate. ??? Spunky tell em mateChris W said:sounded like he wanted em to be removeable in the near future.. otherwise... yeh, dab emwarriorupnorth said:Chris W said:why not batten the wall out with 25mm tile lath and use a vapour barrier..
