Thin coat expansion bead
S a plastering
Do they do one on a job at the mo bottom half is just normal brick then from chamber level goes onto cement board so along the joint on the drawings is an expansion bead at chamber or is it a case of two stop beads back to back filled with poly sulphide thanks
Hi Madmonk, if you are struggling, we stock 6mm Expansion in White or Cream
