thin coat
marmorit is geared up for thin coat. its there flagship product (warmwall) they also do monocouche.
IMO very a good system - one of the best by far
again as I type this I have approx 3/4 bag of sm700 on my shorts and legs.
I should of thought by mon/tue ill be covered in 1.5mm conni
bobby said:
does anyone know adrian from wetherby`s.he vers south west.was gonna use them.can i use them if spec says marmorit?
I would follow the spec mate, if you went behind there backs and used a different product you wouldn't have a leg to stand on if summat went wrong. If your more used to using wetherby then maybe have a word with the developer and see if you could twist their arm into using it instead of marmorit
dont use something that is not on the spec. are you are asking for a lawsuit or what? if you really wanna use wetherby try to get the spec changed by the archi or the MC,s specifier
