thin coat
clivo
doing thin coat render over an old sand and cement tyroleaned house, was thinking micro first followed by hp12 with mesh , primer then TC 1.5 . unless anyone else has any other ideas? Cheers
This stuff is a internal product
Didn't know that, i knew thistle bond it is only to be used internally,the stuff i use is similar to knauf ,i just thought it was the same it called wimatec and can be used externally
thin coat
