CTPlastering
Least we can still have a laugh , all the debate in the other thread , no one has a word but the government haha . I think ur canny for a londoner ;-)
I always mix my own and have used the same sand for the last five yearsThe only down side of s+c is the mixing and variations of sand in the area.
Shouldn't really set next day tho should yaRarely use lightweight backing plaster seem to always go with s and c maybe coz of the properties I work on mostly. You can skim next day so no probs, and cheaper with no chance of catching rising damp when the customer goes on holiday![]()
The whole fu cking place needs knocking downFrom the East Midlands near Leicester not quite as far north as you.newcastle area?i worked there once they knocked an estate down on a big slope I think It was scottswood but may be wrong.
The whole fu cking place needs knocking down![]()
Is that Whitby ?Im actually down near the coast , and its nice down here , near whitley bay which used to be a good stag place lol
Na not miles way , near north shields really which is at the mouth of the tyne .Is that Whitby ?
Tough coat is sexual. To spray and hand apply. Just no1 seems to stock it
Why cant you make bonding for high suction? I will buy a bag of bonding before I would even consider hardwall or tough coat because it has all the uses, fair enough it will pull in quicker on normal brick but if you control the suction it's fine. I wouldn't recommend floating a whole room with it cause the others are nice to use. The new bonding isn't as sticky and a bit more like hard wall but ok to use and what's the point of browning these day? Combine all the plasters so you only need one also what's the crack with the new drywall adhesive?
Great, glad you like ToughCoat. What do you use when you can’t get hold of it? And why do you think ToughCoat is better? Also lets us know where you are and we might be able to point you to a stockist nearby if we know one!
