Nisus
Elite Member
@Nisus is the boy to ask about mixing bonding/multi. :RpS_thumbsup: He gave @Fibrehand7 some great advice about mixing process and ratios. It's what makes this forum great , making bread & butter together
Yes I really should start charging for this info :rolleyes)
These were my answers to his questions about mixing bonding & multi,
think he got a little confused :rolleyes)
Sorry Ryan love ya really :flapper:
Did you know that if you mix 50/50 multi with bonding the bonding will go off quick, but if you mix 50/50 bonding with multi the multi will not go off as quick so make sure you add it the right way around.
Oh & make sure you check if the area you are working in is soft water or hard water, as you will use less or more water depending on which it is, as some water is wetter than others.
Make sure you add it the correct way round or your asking for trouble.
Bonding first, then soft water, then multi, splash of Worcester sauce to hold it off a bit.
But if it's a hard water area add the multi first or your in the sh1t.
Unless you want it to go off slower then add in reverse & vice versa for soft water area.
