john.pitman6
How long do you leave after flattening before you spongeSo.... What am I doing wrong![]()
Sent from my SM-G925F using Tapatalk
I leave until plaster feels slimy then spongeHow long do you leave after flattening before you sponge
I don't ever float after putting a trowel over it.So.... What am I doing wrong![]()
Which sponge , orange ?I don't ever float after putting a trowel over it.
Let it pick up more than you usually would before flattening.
I usually float about ten--twelve SQM before turning back.
I don't like the coarse sponges some use either.
As I've mentioned in the past, I use a carpet float.Which sponge , orange ?
Well it would all depend on how many metres you're putting on.So gear on , chill for 20/30 minutes depending , sponge , flatten, flatten, cross trowel , done ?
I only do price work!leave it vince ...its bullshit.
im not the best spread in the world.
but sponge skimming is when youve lost your way.
more mess more hassle more time consuming.
any fella on here who skims with a sponge are not on price work.
id cover more ground alone without a sponge or machine.
id find it impossible to skim what i can a day sponging....no way could i skim big 4/5 bed plots staircase wet areas espcially ceilings sponging....in 4/5 days miller and jones homes are big plots over 500m.I only do price work!
It cuts out one trowel per move.
and thats there smaller plots !!
makes me cringe sponging a ceiling![]()
You probably right Algee mate I did say earlier I only do small mixes , thing that intrigues me about it now is there seems so many that say they do it , ive tried every thistle plaster there is available and notice a slight difference in all of them compared to each other , but the sponge on multi i just wanted to see if it was any difference to the actual finish
I've never sponged as a matter of course, just when conditions dictate.id find it impossible to skim what i can a day sponging....no way could i skim big 4/5 bed plots staircase wet areas espcially ceilings sponging....in 4/5 days miller and jones homes are big plots over 500m.
You are a f**k**g machine mate and I take my hat off to you.dont take my word vince x
like i said theres lads out there make me look useless.
@essexandy is a top spread and knows his game.
i just found a way that suits me.....its called chase your arse all the time to look after your daughters![]()
One coat mate I assumeI get it perfect every time
Lay on
Speedskim
Leave 20 mins
Sponge
Steel trowel
Leave 20 mins
Remove all the fat with Steel trowel
Finish with ox flexi
Dry trowel
Job done
Dont see the need personaly if you 2 coat. Lay in, 3 trowels, Set done.. Isn't sponge just adding an extra trowel? Maybe I'm missing something.
Too long in the tooth for one coatOne coat mate I assume
Tidy. Exactly mate. What's a sponge for when you can turn out work like that with a couple of passes? But each to their ownthats a small set.
staring at this shite is sending me loopy.
Tidy work.thats a small set.
Been dabbling with the sponge again lately, had some walls to skim over blue grit and couldn’t get the multi to behave and it takes forever to wait for that first coat to pull in on blue grit the sponge came in useful also today skimming over some hardwall that had been floated a while ago gave it a lick of pva but had the sponge on hand just in case, didn’t really pull in excessively but I sponged anyway and it left a decent finish. Been watching rwf on YouTube and I’m really warming to him, he is the sponge float master. He bloody loves Plastering.
Y not f**k**g give your tools to a f**k**g monkey and let it do the work muppetbeen plastering 32 years and never used a sponge but this last week been trying different methods
2 coats splat it flat then sponge and then 2 trowels seems to go so much nicer and quicker and the finish seems better to
What sort of c**t are you??Y not f**k**g give your tools to a f**k**g monkey and let it do the work muppet
Yes and get a f**k**g shave dip s**t you look like a seral killer muppitWhat sort of c**t are you??
I’m guessing you are a f**k**g mr know it all??
Listen you silly f**k**g prick do you think I give 2 fucks what you think go and take your head for a s**t..Yes and get a f**k**g shave dip s**t you look like a seral killer muppit
