Donzo
That will catch up with you probably in your later years.I done all they mad sets etc,, and my body is done in now at 50.Y work for £200 a day wen u can get £500![]()
Hope it don't for u.
Running them Bentleys dsnt come cheap palThat will catch up with you probably in your later years.I done all they mad sets etc,, and my body is done in now at 50.
As u said there stick another first coat and leave it for a few hours i take it u give the wAll spray of water b4 2nd coatingJust to add @ lodan when your feeling More confident....
A good little tip is to try and have a few different areas on the go but only very small manageable amounts and get into the habit of mixing up and laying Gear on in between trowels some areas may be on there 1st coat, some 2 and some wet trowel and so on...
As a quick starting point to which you can't f**k up would be next time your 2nd coating an area knowingly mix a bit more up and 1 st coat a little wall etc...doesn't matter if you don't top that area for couple of hrs providing its flattened off and edges are left tidy etc...
Your then already a good hour plus up on your day etc
@zombie If you do that can you then just second coat and done? Even if you left it for a few hours? thats brand new on my but sounds an awesome tip if thats case...As u said there stick another first coat and leave it for a few hours i take it u give the wAll spray of water b4 2nd coating
Hi fartarm do you think everything in plastering is that black and whiteIt tells you on the back of the bags ffs...
First trowel..second trowel etc..
Simple.
Hi sillybite... According to bg it's black and white?Hi fartarm do you think everything in plastering is that black and white
You might be on to something there, it doesn't look like a bad finish - just a total failure to adhere.Classic unfinish job
Quality work that scottie5,what's your process?
Tried this method today,how do fill any misses you may have?i find the super flex trowels don't take anything off to fill misses out or do you do it with the speed skim?cheers.
theres no 2 pallets of finish seem to be the same at the moment but in an ideal world.
i fill board tapers.
2 coats.
speedskim a couple of times.
then 1or2 passes with a mediflex depending on how the gears behaving then 1 dry cross/polish.
Do you always have the uniform flawless finish on whatever you skim onto with this method?
It's a waste of time taking pics of skimming as you cannot see the quality
Trouble is I can't take pics when it's painted cos they won't have me back!![]()
I have no idea how many trowels wet or dry I do... it gets what it needs![]()
I've worked with lads like headless chickens, s**t everywhere water everywhere troweling up like mad men.
Same here or when to go back on it. Just to many variables.
No water with the sexflex scottie5?
Layed on today using nela premium, 2nd coat with mediflex, brushed in corners/edges then speedskim till finished. Lovely job easily completed. My shoulder lurrrrves my speedskims.....
No water with the sexflex scottie5? Do you find trowel or speedskim direction alters finish? Or any old way. Cheers
[emoji106]
