Two bonding coats
Server
Can you put another thin (3mm) bonding coat on top of a thick (8mm) bonding coat ?
Will it fastern ok if I pva it ?
Thanks I assume a 4mm finishing coat would not be a good idea and would not bond well to the bonding coat ?
If it's 8mm and 3mm why did u not stick a 9mm pb on it and scim. It. I always get a straight edge and if can get a board on it.make good with bonding rest of wall.
Because I wanted to leave enough room for a skim coat, but did not get it quite right, as I am not skimming the whole wall it has to be level with the rest of the wall.
I think there may be trouble ahead for you.Do send us pics.
