Much better even colour that wayI don't bother with Cullamix, I use whatever OCR I've used for the base, tell them to get the painter in
Does weber ocr flick on ok mateI don't bother with Cullamix, I use whatever OCR I've used for the base, tell them to get the painter in
Yes it's sound mateDoes weber ocr flick on ok mate
Do you wind it on or use a compressorDoing loads of tyrolean tomorrow I fkink hate the stuff!!
Winding it on mate its sand and cement I gotta match a load of garden walls same as shitty house!!! So can be as rough as I like it's hideous!Do you wind it on or use a compressor
No Mrs palm for you tomorrow evening.Winding it on mate its sand and cement I gotta match a load of garden walls same as shitty house!!! So can be as rough as I like it's hideous!![]()
Done a fair bit myself seemed to be most jobs when I started out with my old man, still get a few jobs down Devon seems to be a lot of it especially coastal!there is a knack to it , did loads of council houses and pit houses back in the day.
if done right its one of the better finishes - it depends if the customer wants a heavy texture or light texture
Old school gunDo you wind it on or use a compressor
Cheers palYes it's sound mate
Yes it's better than cullomixCheers pal
Manufacture does not recommend using darker colour during winter, chance of lime bloom.Doing loads of tyrolean tomorrow I fkink hate the stuff!!
Surprised by thatManufacture does not recommend using darker colour during winter, chance of lime bloom.
Surface dry but moisture in background.
